Re: working on a new chiller........
Thanks, after studying this stone, I think I will add to it when I get some more foam scraps, I have a few ideas that will make it more 3 dimensional I think
Thought you'd appreciate this Spooky, guy is testing out his AtmosFearFX videos on a fog screen. Awesome effect.
More info on the fog screen...
It is an old Sharp Notevision projector, and the fog screen is a box with 14 computer fans that create 2 walls of air. Fog is pumped through a 4" PVC pipe in the center with a slit cut lengthwise along the pipe. I need to add drinking straws to channel the air from the fans for a cleaner flow.
well, the <deleted>-hats at FB closed my Halloween account because I refused to use my real name (I have a personal FB for that) so I guess I'll have to just update straight to here from now on.....
This site is better then FB anyways.
Okay, here are the beginnings of a few "props", one is a column that will look like brick and the second is a groundbreaker coffin that (if everything goes right) will bang its door as someone walks by.....
- 2.jpg (32.04 KiB) Viewed 112458 times
- 1.jpg (55.92 KiB) Viewed 112458 times
Dat's a pretty fine right angle on da column dere.
Did ya eyeball dat er 'dja yoose a angle iron ?
(Apologies ; when around a workshop or reading a diy I start channeling my northern Michigan ancestors )
I used the actual column I am going to wrap this around as a "mold"
k, made some headway on the coffin........
- 20141025_163225.jpg (153.45 KiB) Viewed 112394 times
- 20141025_163215.jpg (142.66 KiB) Viewed 112394 times
- 20141025_163156.jpg (142.15 KiB) Viewed 112394 times
more......
- 20141025_163306.jpg (228.7 KiB) Viewed 112393 times
- 20141025_163243.jpg (106.73 KiB) Viewed 112393 times
and with some paint and an image of what I'm going for with the look of mine....
- 20141025_203136.jpg (153.92 KiB) Viewed 112393 times
- oldcoffin_checkmatedark16accfbbe-f33a-47a9-b370-d19b0fab8f2blarge.jpg (85.52 KiB) Viewed 112393 times
9200 posts, you're catching up old boy.
The wood grain detail is very convincing.
k, all painted up and I have the motor installed but I need to wait a day or so for the adhesive to dry completely before I can test it
- 20141026_204814_LLS.jpg (99.73 KiB) Viewed 112374 times
Spooky, you really need to quit your day job and start a business selling your props.
Yeah, you are great at this!
Thanks guys!
Did some more painting today on one of my brick columns.......I keep getting asked why am I making a column that looks JUST like the column thats there, well, I cant drill holes and mount lights in the actual column, I would have a mess of wires dangling all over, so doing it this way, I can hide the wires (and this really messes with the maintenance man too, he keeps thinking I messing up the building
I still have the weathering to do to it but here is the real one and my fake foam one
- 1.jpg (167.3 KiB) Viewed 112303 times
