Haunt Hobbyist
NEW 2016 PRODUCT RELEASE from Haunt Hobbyist: SCREAM BOX PRO
Post by Haunt Hobbyist » Fri Aug 26, 2016 8:31 am
Our Scream Box Pro was just released on 8/25/16
The Scream Box Pro is the same as the Original Scream Box except it is even easier to load your Scary MP3 Sounds and LESS EXPENSIVE ($24.99 shipping included). It uses a USB Cable instead of an SD CARD (SEE 2nd Picture). The Scream Box Pro is the only battery operated product that works in Complete Darkness, programmable, and has awesome sound quality. Since you are able to program your own MP3 sounds, you can match it to your Haunt Theme or Prop. The Scream Box Pro has a heat sensor which works perfect in a well lit room or in the dark. The speaker is loud.
Scream Box Pro is available on Ebay (type in Scream Box Pro) and http://www.haunthobbyist.com
Let us know if you have any questions.
