New Product Release from Haunt Hobbyist: Heat Ghost
Haunt Hobbyist
Post by Haunt Hobbyist » Sun Jul 05, 2020 10:37 am
It has been 30 years since the Sonic Ghost was invented. We believe this amazing product started the Animated Halloween Product Industry. That is why Haunt Hobbyist is so excited about bringing this classic product back with updated technology to turn the Sonic Ghost into the Heat Ghost. When you walk in front of the Heat Ghost it activates and shakes, lights up, and plays the old classic Sonic Ghost sound for about 10 seconds and then stops until it is activated again. The Heat Ghost does NOT respond to sounds, only motion (body heat). The Heat Ghost works a DARK or LIT room. A bright light fixture will cause the sensor to activate. Use indoors or front porch to surprise visitors when they come to the door. When you hang the ghost, make sure there is no motion such as ceiling fans etc (Wind can set off the sensor). Must use black stabilizing bar in the middle of the string (included). Hang on hook or a LONG nail so the Heat Ghost does not fall due to its strong shaking (string can lift up and over a short nail while shaking). The PIR Sensor must be facing you in order to activate. It only has one PIR Sensor on the forehead of the face, it does not activate from behind. The higher you hang the Heat Ghost the further back you need to be in order for the sensor to see you. Sensor can see you 15 feet away. Another option customers have told us is hanging the Heat Ghost with its back touching the wall (works great and makes a tapping noise).
Heat Ghost $17 Available at www.haunthobbyist.com
Here is a video of how it works:
https://www.youtube.com/watch?v=WVdsa2ZriEY
heat ghost1222.jpg (181.32 KiB) Viewed 24528 times
Pumpkin_Head
Re: New Product Release from Haunt Hobbyist: Heat Ghost
Post by Pumpkin_Head » Wed Jul 08, 2020 7:03 pm
I would like to have a few of those things to put up around the house for October.
