The Scream Box Plus is the only battery operated product that works in Complete Darkness, is Programmable (add your own sounds), has awesome Sound quality, and plugs into an amplifier.
The Scream Box Plus is HEAT ACTIVATED so it can see in the dark. It is perfect for haunts and easy to setup and operate (no power outlet needed). Just copy your MP3 files to the Scream Box PLUS (up to 8MB / 210 seconds) and it repeats each MP3 file out of the built in speaker each time the heat sensor is activated. The sensor can see you from 12 feet away in the dark or a well lit room. There are two modes of operation, which are changed by pressing and holding for 3 seconds button A (until LED light blinks). Mode 1 means the Scream Box Strobe will play all MP3 sounds, one by one, each time the sensor is activated. In other words, you can put it in your prop and it will say different things each time the heat sensor is activiated. There is 210 seconds of memory that can be stored. That is a lot of different phrases your prop can say. Mode 2 means it will repeat the same MP3 sound you choose in your list over and over. The Scream Box Strobe (2"X 3.5"X 1") has a mounting bracket for easy setup. Once mounted, you can turn the Scream Box Strobe in any direction you want. It has 2 volume settings (Low volume and High volume) (3 AAA Batteries are not included). To get your MP3 sounds on the scream box plus you must delete some of our MP3 files on to make room. It is easy to program, just plug the USB into your computer. Plug the Micro USB into the Scream Box Strobe. Next, transfer your MP3 Sounds. Some of the MP3 sounds that are included on the Scream Box are chainsaw sound, car horn, evil laugh, air blast, zombie moaning, swarming flies/bees, evil laboratory sound, factory alarm (loud) etc. When you are ready for different sounds, just add new MP3's to the scream box. $24.79 at www.haunthobbyist.com
- Haunt Hobbyist
- Zombie
2021 SCREAM BOX PLUS - Programmable speaker that plugs into amplifier
- screamboxamp2.jpg (1.48 MiB) Viewed 23700 times
- Scream box12logo2.jpg (686.12 KiB) Viewed 23700 times
Pumpkin_Head
Re: 2021 SCREAM BOX PLUS - Programmable speaker that plugs into amplifier
That's quite alright. My amp is more then adequate to the task. All I need is that scream box!
